Skip to main content
Version: current
Netwatch
Netwatch monitors the state of hosts on the network. Monitoring can be done with the following probe types:
  1. ICMP - pings to a specified IP address - hosts, with an option to adjust threshold values
  2. Simple - uses ping, without the use of advanced metrics
  3. TCP conn, to test the TCP connection
  4. HTTP GET/HTTPS GET, a request against a server you are monitoring
  5. DNS - sends a DNS query to a DNS server and checks for a response.
For each entry in the Netwatch table, you can specify an IP address, ping interval, and console scripts. The main advantage of Netwatch is its ability to issue arbitrary console commands on host state changes.
info
Since 7.4, Netwatch functionality has been expanded; prior versions only support simple ICMP probes. While upgrading to the new version, old Netwatch entries will be unchanged, reporting probe type "simple" - preserving the same functionality.
Warning: Default Netwatch values are always used - even if they were not defined by the user. Make sure to check the "status" page of the probe to see if the default thresholds are appropriate for your use case. Default threshold values can be found under the "probe options" section on this page.
Properties
Sub-menu: /tool/netwatch
PropertyDescription
host (Default:"")The IP address of the server to be probed. Formats:
  • ipv4
  • ipv4@vrf
  • ipv6
  • ipv6@vrf
  • ipv6-linklocal%interface
  • domain name (for type=dns)
type (icmp | tcp-conn | http-get | http-get | dns | simple; Default: simple)Type of the probe:
  • icmp - (ping-style) series of ICMP request-response with statistics
  • tcp-conn - test TCP connection (3-way handshake) to a server specified by IP and port
  • http-get - do an HTTP Get request and test for a range of correct replies
  • https-get - do an HTTP Get request and test for a range of correct replies
  • dns - do a specified DNS query for the domain name
  • simple - simplified ICMP probe, with fewer options than "ICMP" type, used for backward compatibility with the older Netwatch version
interval (Default: 10s)The time interval between probe tests
timeout (Default: 3s)Max time limit to wait for a response
src-address (Default: "")Source IP address which the Netwatch will try to use in order to reach the host. If the address is not present, then the host will be considered as "down".
start-delay (Default: 3s)Time to wait before starting the probe (on add, enable, or system start)
startup-delay (Default: 5m)Time to wait until starting the Netwatch probe after system startup
up-script (Default:"")Script to execute on the event of probe state change 'fail' --> 'OK'
down-script (Default:"")Script to execute on the event of probe state change 'OK' --> 'fail'
test-script (Default:"")Script to execute at the end of every probe test
ignore-initial-up (no | yes; Default: no)Specifies if "Up" script should be run if the probe state change goes from Unknown to 'Up', used to help against false positives after enabling the probe, or after a reboot. "no" means that the change from Unknown to Up will not be ignored.
ignore-initial-down (no | yes; Default: no)Specifies if "Down" script should be run if the probe state change goes from Unknown to 'Down'. "no" means that the change from 'Unknown' to 'Down' will not be ignored.
Warning: Should be used with care, as the first "Down" status won't be executed, and Down script will only be run if the probe goes through "Up" > "Down" state.
Netwatch executes scripts as *sys user, so any defined global variable in the Netwatch script will not be readable by, for example, a scheduler or other users
danger
Netwatch is limited to read,write,test,reboot script policies. If the owner of the script does not have enough permissions to execute a certain command in the script, then the script will not be executed. If the script has greater policies than read,write,test,reboot - then the script will not be executed as well. Make sure your scripts do not exceed the mentioned policies.
It is possible to disable permission checking for RouterOS scripts under the /system/scripts menu. This is useful when Netwatch does not have enough permissions to execute a script, though this decreases overall security. It is recommended to assign proper permissions to a script instead.
Type-specific options
All config options specific to one probe type (e.g. icmp's packet-interval) are ignored for other probe types.
ICMP probe options
PropertyDescription
packet-interval (Default: 50ms)The time between ICMP-request packet sends
packet-count (Default: 10)Total count of ICMP packets to send out within a single test
packet-size (Default: 54 (IPv4) or 54 (IPv6))The total size of the IP ICMP packet
thr-max (Default**: 1s**)Fail threshold for rtt-max (a value above thr-max is a probe fail)
thr-avg (Default: 100ms)Fail threshold for rtt-avg (round trip time-avg)
thr-stdev (Default: 250ms)Fail threshold for rtt-stdev
thr-jitter (Default: 1s)Fail threshold for rtt-jitter
thr-loss-percent (Default: 85.0%)Fail threshold for loss-percent
thr-loss-count (Default: 4294967295(max))Fail threshold for loss-count
ttl(Default; 255)Manually sets the time to live value for the ICMP packet
accept-icmp-time-exceeded (yes | no; Default no)If the ICMP "time exceeded" message should be considered a valid response
early-failure-detection (no | yes; Default: no)Netwatch will not wait for all the packets to be processed to change probe status if it is already known that the host will be considered "down".
early-success-detection(no | yes; Default:no)Netwatch will not wait for all the packets to be processed to change probe status if it is already known that the host will be considered "up".
info
accept-icmp-time-exceeded=yes can be used together with a manually set low ttl value to monitor Internet connectivity, without relying on a specific endpoint.
For example, you can monitor a public IP address, but that address can filter your ICMP request, or just become unreachable itself, if the Netwatch probe is using this address to monitor Internet connectivity, this would cause a false alarm.
To make sure you can reach the Internet, it's generally enough to make sure you can reach a device a few routing hops away. A low time to live value will expire in transit to the specified host you want to monitor - each router passing the ICMP packet will subtract "1" from the TTL value, upon the TTL reaching 0, an ICMP "time exceeded" packet will be generated, and sent back to the Netwatch probe. If all other fail thresholds are not broken, this response will be considered a success.
Important: When writing Up/Down/Test scripts for Netwatch, use the rtt-* elements instead of the thr-* elements. If the element names differ, their script-specific forms are listed in the description.
Important: Simple, ICMP, HTTP, and TCP-connect probes are sent with the "don't fragment" flag set. With an ICMP probe, you can set packet-size, which in combination with the DF flag, can be used to aid with path MTU discovery.
TCP-CONNECT
PropertyDescription
port (Default: 80)TCP port (for both tcp-conn and http-get probes)
TCP-CONNECT pass-fail criteria
PropertyDescription
thr-tcp-conn-time (Default: 00:05...00:30)Fail threshold for tcp-connect-time, the configuration uses microseconds, if the time unit is not specified (s/m/h), log and status pages display the same value in milliseconds.
HTTP-GET probe options
PropertyDescription
HTTPS-GET probe options
PropertyDescription
port (Default: 443)TCP port (for both tcp-conn and http-get probes)
certificate (Default:"")Certificate from the local store that should be used for host verification.
check-certificate (yes | no; Default no)Enables trust chain validation from the local certificate store.
HTTP-GET/HTTPS-GET probe pass/fail criteria
PropertyDescription
thr-http-time (Default: 10s)Fail threshold for http-resp-time
http-code-min (Default: 100)OK/fail criteria for the HTTP response code.
http-code-max (Default: 299)Response in the range [http-code-min , http-code-max] is a probe pass/OK; outside is a probe fail. See mozilla-http-status or rfc7231
DNS probe options
PropertyDescription
host (Default:"")DNS name that should be resolved.
record-type (A | AAAA | MX | NS; Default: A)Record type that will be used for DNS probe.
dns-serverThe DNS server that the probe should send its requests to; if not specified, it will use the value from /ip/dns.
Probe statistics/variables
You can view statistics and use these variables in scripting. Keep in mind that variables containing "-" must be written like this, for example, "done-tests" would be $"done-tests"
Generic:
PropertyDescription
nameuser added name for the Netwatch entry
commentuser added comment
hosthost that was probed
typeprobe type
intervalinterval
timeouttimeout
sinceThe last time the status change happened
statusThe current status of the probe
done-teststotal count of probe tests already done so far
failed-testscount of failed probe tests
ICMP:
PropertyDescription
sent-countICMP packets sent out
response-countMatching/valid ICMP packet responses received
thr-loss-countnumber of lost packets
thr-loss-percentnumber of lost packets in percent
thr-avgmean value of round trip time (rtt-avg)
thr-maxmax round trip time (rtt-max)
thr-jitterjitter ( = max - min) of round trip time (rtt-jitter)
thr-stdevstandard deviation of round trip time (rtt-stdev)
TCP:
PropertyDescription
tcp-connect-timetime taken to establish a TCP connection
HTTP:
PropertyDescription
http-status-codeHTTP response status code (200 OK, 404 Not Found, etc.). See mozilla-http-status or RFC7231
HTTPS:
PropertyDescription
DNS:
PropertyDescription
ipIP address - the result of A record-type probe
ip6IPv6 address - the result of AAAA record-type probe
mail-serversMail servers along with their priorities - the result of MX record-type probe
name-serversName servers - the result of NS record-type probe
Logs
On each probe's OK/fail state change:
  • Probe identification info and OK->fail or fail->OK are printed to info level.
  • Detailed probe stats and config are printed to debug level.
Status
Command /tool/netwatch/print will show the current status of Netwatch and read-only properties:
  • since - Indicates when a state of the host changed last time.
  • status - Shows the current status of the host.
  • host - address being monitored.
Quick Example
Here we will use a simple ICMP check to the host with IP 8.8.8.8:
[admin@MikroTik] > /tool/netwatch/add host=8.8.8.8 interval=30s up-script=":log info \"Ping to 8.8.8.8 successful\""
Afterward, in the logging section we can see Netwatch executed script:
[admin@MikroTik] > /log/print where message~"8.8.8.8"
08:03:26 script,info Ping to 8.8.8.8 successful
